Anyone thought about getting the Carvex + accessory kit all in one systainer?
amt
I occurred to me it might be nice to fit the Carvex and the contents of the accessory kit all in one systainer.  I don't have a sys3 to check, but I was hoping that might do the trick.  I would have the Carvex lay upright (and not on the side like it comes), and then create some dividers to hold various bases.  I guess I need to take some measurements.  Anyone know what the -inside- height is for a sys3?
I think it would be a pain to have everything jumbled together personally.  I like the accessory Systainer with everything organized.  With that said, if I were buying over again I would probably just get the circle cutter attachment with the basic saw and skip the other bases -- it has worked for my application so far and that would fit in one Systainer without an issue.
Scot
I seem to remember seeing a picture here somewhere, where a member had used a sys2 and had the bases on a bottom and the saw and spare blades on a top tray, looked like something I might do if I had a carvex [sigh]
Sys - III is about 7" inside height +/-  depending on the exact location. If not using an attic lid there is a little height inside the lid too.
The five drawer Sortainer might do the trick too.
I did it, and it works well.  The Carvex and the accessories all fit in the Sys 2 the Accessory kit comes in.  I just built some plywood dividers in the bottom, then took the Carvex tray out of the Sys1 and placed it on top.
See the thread:
Carvex and Accessories in a Sys 2
I was thinking about this this morning and wondered if the OP wanted to keep/use the inserts for the Carvex -and- the accessories.  If so, then how about using a Sysmaxi?  It's two standard sized Systainers, side by side. Since the 'tainer would be carried from the side, rather than upright, perhaps a thick piece of foam attached/glued to the lid would keep everything in place during transport.
JMTC...
