fuzzy logic said:
Hi. Just read your post, and it brought back vague memories.
I didn't think they were the same, but that was as far as it went - lol.
So, googled "split point" and "four facet". All will be revealed - interesting, but, I found some of the info' heavy going.
A couple of quotes:
"A split point can have four facets."
"A four facet doesn't have to have a split point."
Must admit, it made me think about what bits I'll use for metal in the future (have lots of bits to use first though.)
Basically, it seems, can drill cleaner, quicker (with less effort) than with 'conventional' bits.
Just curious - what's your interest?
Richard.
I'm looking at two different sharpening systems for drills.
The Drill Doctor DD750X talks of sharpening split point drills and has a sharpening method that sharpens the primary cutting surfaces (the drill is fitted in a specialised chuck and you rotate the chuck in a cam socket against a cylindrical diamond cutting wheel). Applying the "split point" involves sticking the chuck containing the drill in a side socket of the Drill Doctor, but I haven't found a good technical description of the result achieved.
The Tormek drill sharpening jig is a bit of a beast, but videos explaining it's use show a solid procedure for producing a four facet sharpened drill bit - it seems to be a plodding, structured, methodical procedure. None of the Tormek procedures refer to "split point".
So the question is probably about the effective resulting drill geometry.
I'm also on the fence about the Drill Doctor because of the "air cooled" method of sharpening ... various schools of thought consider both the Drill Doctor and Worksharp methods of "air cooled" sharpening to be a bit misleading in that they both heat the sharpened metal tip and introduce a degree of brittleness to the metal, where a slow moving whetstone does not (e.g. Tormek).
... The fear hear is that the Drill Doctor is quick and easy, but produces a edge that blunts quickly v's the Tormek that "could" be creating a more lasting edge.
In the past I've only ever used a contraption that sharpens a drill bit against the side of my grindstone - very poor results. As you'd expect - I have a lot of drills now!
A further part of the conundrum is that the various sharpening systems are only good for common types of drill bits. Also, go under 3mm or over ~23mm are you need a different sharpening tool (and who sharpens under 3mm anyway?)
If there was a "cash for blunt drill bits" service I wouldn't even be considering a sharpening system!
