Assembly/Finishing Strategy
gunnyr
Cincinnati OH
As I posted earlier I am finally having some success with spray finishing.  I delivered a project today that I sprayed with my Fuji MM4 and SW Pro Classic Gloss.  This is a ramp to make it easier for their dachshund to climb up in bed with space for the lady to display some of her shoes.
Finishing the piece was quite a challenge for me.  I finished all the interior before assembly and then masked the interior and finished the exterior.  I was worried about the transition from the interior to exterior finish but I masked it at the trim joint and it worked out well, only a little touch up was needed.
[attachimg=2]
The customer was happy enough with the piece and asked me to build a mid-century nightstand for them!
My question is how to best go about finishing the piece.  Below is a CAD drawing of the piece.  It will have an open back.  It will be built with edge banded Baltic Birch Plywood.  I'm thinking I'll miter the corners and install the fixed shelf with dominos.  My thought is to finish the interior before assembly just like the ramp.  Am I missing something, is there a better approach?
[attachimg=3]
Open back, just spray it from both sides.
You need to learn to roll the gun around the interior intersections. The will leave you with small areas of the sides to spray in. This prevents build along the corners.
That unit is small enough where dry fall should not be an issue.
Thanks!  I was concerned about getting the gun in the area above the shelf.  I'm thinking it might be worth making a cardboard mock up to practice with.
