onocoffee said:[member=74278]Packard[/member] …seems that a number of the woodworking influencers like to tout both Bits & Bits and the Astra coated (Whiteside) bits.https://bitsbits.com/bits-bits-astra-coating
woodferret said:It'll be TiSiAlN. It's developed by SHM and marketed by Platit? Personally I view it as a gimmick for woodworkers. The TiAlN standard bit looks dull and grey in comparison to the rainbow colors.
Edit: I guess they've licensed it out to various manufacturers. Doesn't matter though, it's still lipstick.
luvmytoolz said:Small profile cutters like cove, roundovers, rebate cutters, etc, I also generally buy the cheaply available ones as for these small routing tasks I fail to see any benefit in the more expensive ones. Sure a 4 flute roundover is going to give a smoother result in use, but at 4-6 times the price over a 2 flute, the end result is the same. So unless you're going to stick to one or two sizes and use those specific sizes a real lot, there's no perceivable value in my opinion for the more expensive ones.
onocoffee said:luvmytoolz said:Small profile cutters like cove, roundovers, rebate cutters, etc, I also generally buy the cheaply available ones as for these small routing tasks I fail to see any benefit in the more expensive ones. Sure a 4 flute roundover is going to give a smoother result in use, but at 4-6 times the price over a 2 flute, the end result is the same. So unless you're going to stick to one or two sizes and use those specific sizes a real lot, there's no perceivable value in my opinion for the more expensive ones.
This is reassuring - as I recently bought some American Vermont 1/4" shank Pattern and Trim router bits recently!
onocoffee said:I see quite a few people online talking about Astra coated Whiteside router bits from Bits & Bits. Hype? Or worth the effort to get?
