Attaching Kaypex to the side of a MFT 3
ToddLegere
Is there an attachment to allow the Kaypex to attach to the side of of MFT ?  Basically a double V clamp.  My Kaypex is at the exact height, so im hoping there is a way to lock it to the table.
Not from Festool, but it's relatively straightforward to build one from a piece of plywood (to bridge the gap), two glued-on triangular strips (to register in the v-groves of Kapex and MFT), another piece of plywood (to function as a clamp from below) and a knob that goes with the screw into a matching T-nut in the bridge piece ontop.
Im guessing if you were to get a Kapex MFT or build a stand for the apex the exact height of a Kapex MFT that would meet your needs as the Kapex MFT with the Kapex mounted on it will be the exact height of the MFT (900mm).
hope this helps
As is the Kapex on the UG cart.
