Bandsaw Dust Collection
dlu said:
It's a little hard to tell from the photos but the before is about 1/2 a cup (quite a but came out the standard vacuum connection as well as around the lower wheel, after is less than a tablespoon.
One thing that seemed to help collect more dust is when I drilled holes into the table insert. It keeps the top of the table a lot cleaner.
The replacement inserts for my Rikon BS come already perforated.
I would have thought they all do.
I built a version of the Blake Weber dust collection adapter for my Delta bandsaw.
It works pretty well.  Though not the first time I tested it as I forgot to turn on the CT22.  It worked much better after I turned on the CT22 :-)  Some pictures:
[attachimg=1][attachimg=2][attachimg=3]
I may have made the kerf for the saw blade too large, closing up it up a bit might improve the performance, but I suspect it doesn't matter that much.  I used a modified Festool 500593 Crevice Nozzle to connect a 36mm hose.  I cut off the angled part.
I also discovered that Cyanoacrylate glue works well to glue in the magnets.    Much easier than mixing and waiting for epoxy to cure.  I am finding more uses for CA glue over time.
Bob
dlu said:
It turns out that there is a lot less clearance between the table and the lower guides on a Jet saw than on the Delta – like 12 or 14 mm. So, I decided that Blake Weber's idea would be hard to pull off, especially with the materials I had on hand. But I still wanted the dust to go away and the space requirements, power consumption, and noise of a "real" dust collector all suggested that it was at least worth trying to get my CT36 to do the job.
I figured that if I couldn't get a huge volume of air, perhaps concentrating the suction close to the blade might work. So, I built this:
[member=31317]dlu[/member]  isn’t that black tube a dust collection chute? Doesn’t it work better than the little pvc tube running perpendicular to the flow of debris?
Michael Kellough said:
[member=66813]rmhinden[/member]  and [member=44099]Cheese[/member]  which aftermarket guides are you guys using?
[member=66597]Mario Turcot[/member] you’re 2 for 2.  [big grin]
[member=297]Michael Kellough[/member] they’re Carter 2300 series. The micro adjust wasn’t available when I installed mine.  [sad]
[member=66813]rmhinden[/member] my Delta was purchased in 1993.  [cool]
[member=31317]dlu[/member]  isnt that black tube a dust collection chute? Doesn’t it work better than the little pvc tube running perpendicular to the flow of debris?
[/quote]
Yes, it is. The black tube, the stock dust collection point is just "in the vicinity of" the dust coming off the blade. Attaching a shop vac there gets a fair amount of the dust, but still misses a lot. My "little PVC tube" is just missing the teeth of the blade and seems to do a much better job.
If the stock port wrapped around the blade, like [member=44099]Cheese[/member]'s appears to do (and I had enough air volume) I expect it would work better.
Isn’t that black tube a dust collection chute? Doesn’t it work better than the little pvc tube running perpendicular to the flow of debris?
I had the same item on my bandsaw. It has an ID of 1 1/8" and is at least 1" away from the blade. So it catches some of the stuff, maybe 25%.
Mario Turcot said:
What’s wrong with this picture?
This is what Rockler uses to sell Carter guides.
Thought I might get a set using the Rockler 15% discount (V20610) but they only have the basic model, and this picture of the teeth deep inside the bearing is off putting.
Mucho... [eek] [eek] [eek]
That's just a very bad picture Michael...it's tragic that they'd even use that for advertising purposes. Get the blade tracking properly first and then do the adjustments.
1/2" wide DoAll wood blade.
3/4" wide Lenox metal blade.
[attachimg=2]
