Bar centres on OF1400/1010 ?
Rob-GB
Could someone kindly let me know what the guide bar centres on these two routers are and their height above workpiece with a standard base plate on?
I am working on a jig for my OF2200 and am trying to work out if I can also make it suit these two routers as they are on my wish list and making a 3 in 1 would save space in the systainer.
Thanks in advance for any info, Rob.
Hi Rob,
The height of the OF1400 is 17mm and the OF1010 is 10mm. That is as close as I can measure at the moment, but they are significantly different heights. The diameter of the guide bars is the same though...!
Centre to centre on the OF1400 is 79mm and the OF1010 is 108mm.
Hope this helps!
Regards, Tim.
Thanks Tim, I take it that the 17 and 10mm are to bottom of the bars?
Very much appreciate your speedy reply.
Regards Rob.
Regards Rob.
No,  [embarassed]....Sorry Rob, those measurements are to the centre of the guide bars from the bottom of the router's base.
Apologies for the mistake..!
Distinctive Interiors said:
No,  ..Sorry Rob, those measurements are to the centre of the guide bars from the bottom of the router's base.
Appologies for the mistake..!
No apology necessary Tim, I was looking at some pics of those routers and trying to judge scale.  [blink]
I tried searching for the relevant info but Festool UK site is all over the place at the moment, even the EKAT tells me to start from the shop after just logging in...I think they need to upgrade from a penknife to beta test what they are doing now [eek]  [big grin]
Thanks again for your help, you're a star.
Regards, Rob.
