There's been recent discussion here about the Jet competitors to the Bessey K-Body clamps.
In addition to their other advantages, the Jets could easily be attached to an MFT.
I've been trying to list the advantages of the Besseys. One is that the Besseys work with their Maxis Vario Pivot. These:
[attachthumb=1] [attachthumb=7]
One of the pair has hooks that engage the head of the K-Body, the other has a socket for the end of the K-Body bar. The Vario Pivots are clamped to a bench edge. The Vario Pivots work with any length K-Body, but since they engage the ends of the clamp, you must have a bench long enough for the K-Body you're using. The Vario Pivots can also be used with pipe clamps, they say.
[attachthumb=2] [attachthumb=3] [attachthumb=4]
In use, the clamp can lay on the bench top or be turned to any angle within 270 degrees, so work can be held on or off the bench.
[attachthumb=5] [attachthumb=6]
Now the bad news--no way is the Vario Pivot compatible with the edge of the MFT. I suppose you could clamp an overhanging board on the MFT to provide an edge the Vario Pivot could clamp to.
Anyone have the Vario Pivots? Anyone use them? Anyone love them?
Ned
Ned
