Cheese
Jimmy69 said:I thought they were both interchangeable? But you're saying the 125 can take the 150 pad but not the other way around? How does that work?
Here's the 125 mm pad on the left and the original Jet Stream 150 mm pad on the right. The 150 mm driveshaft has 2 additional ears which would need to be ground off if you wanted to put a 125 mm pad on it.
Here's the 125 mm drive shaft...no ears.
[attachimg=2]
Here's the newer 150 mm Jet Stream 2 pad on the ETS EC 125.
[attachimg=3]
