Best attachment for carpets (CT)
jahej
I have a CT and often find myself needing to vacuum carpets on the field as it is very common in my country. For this I have to carry around 2 vacuums. The other vacuum is very good for carpets as it has a motorised head especially for carpets. But I want to use my festool for it! I saw Festool used to have a special attachment for carpets (#450644) but it looks like they stopped selling it 10 years ago.
What are my options 2025?
I was surprised to see that they stopped offering that, but it was more recent than 10 years ago. Others will likely pipe in with the applicable head manufactured by the company that made them for Festool but you can find cheap turbine (suction powered brush) ones on Amazon. The Festool one was also suction powered - not electric motor. They really only work with the 36mm hose.
Thanks.
If anyone has a suggestion in EU, please post it :)
I've had on my list to get a Wessel-Work head that has a power cord; plug it into the DC, bam, powered beater head.
I have the one you linked to here; it's OK, but def needs 36mm hose; it also loses power the longer the hose is.
Fein makes one that should work "fine" with Festool, I got one years ago as a freebie with vac.
I have the Wessel 'turbo brush', I believe it came with a reducer to fit the Festool tube. Works very well.
As Sparky mentioned, the Festool 203809 was manufactured by Wessel-Work...model TK 286. Here's some comparison photos.
IMO it's pretty ridiculous that there are no drop in electric options here in 2025
Most of our dust extractors have an automatic outlet on them already, an electric carpet head with a switch could plug right in and be operated easily. One with a 36mm fitting would be amazing for heavy cleanup.
Otherwise, I wish I could power my Dyson motorhead from the AC outlet!
I've had the Wessel-Work one in my cart, for a long time now, but I just don't do enough carpet to justify it.
The floor nozzle from the 36mm hose set I bought does well enough, for the minimal use I have.
Festool 450644 has been superseded by the also discontinued 203809 which is a Wessel Werk TK 286 but with a green slide instead of a blue one and at 2.5x the price. I can imagine more people figured this out and their sales collapsed...
No reducer needed to fit the Festool pipes.
It truly is amazing at pulling hair out of carpet. Comes with a special knife to clean it.
I have to note that the Wessel-Werk turbo head is good on bare floors and short carpet, but chokes up on deeper pile carpet. It also gags on longer dog hair and needs to be cleaned frequently. A powered head would be a better option, if one were available.
