lordinteriors
- Dec 18, 2008
i have the 2700mm rail
WarnerConstCo. said:It's because we just like big things here. [cool]
festooltim said:I have a 2700 and i cut it at 8 feet long [scared] because it always stays in my truck. It slides under a tool box on the side then when i need it i can pull it out and attach the piece that was cut off with rail connectors and it is much easier to handle than my two 55's. Then i don't have to break it down when making cross cuts.
Charimon said:festooltim said:I have a 2700 and i cut it at 8 feet long [scared] because it always stays in my truck. It slides under a tool box on the side then when i need it i can pull it out and attach the piece that was cut off with rail connectors and it is much easier to handle than my two 55's. Then i don't have to break it down when making cross cuts.
That is STUPID like Einstein [thumbs up] [thumbs up]
Craig
CList said:...
It's obviously more convenient to have more overhang - but too much overhang seems like it'd just be a waste - annoying to slide the clamps all that way and annoying if the rail flexes under the weight of the saw.
Corwin said:Accurately placing the rail at the desired location and such that the overhangs are just right is likely more annoying. And stopping the forward motion of the saw at the end after it has completely cut the material yet before the front gib runs off the rail is more than annoying with a rail that doesn't have any excess length. These issues make having a little too long a rail seem more than simply a convenience. Get the longer 3000mm rail for those 8' cuts and the 1900mm rail for the 4' cuts -- you won't regret having purchased the longer rails, but you may regret buying a rail that doesn't quite do the job.
WarnerConstCo. said:Just send your ts-75 to me and then I will send you my ts-55 in return.
harry_ said:WarnerConstCo. said:Just send your ts-75 to me and then I will send you my ts-55 in return.
Darcy,
You could just about talk me into it!
PaulMarcel said:Not to derail this thread, but with respect to the TS-75 vs TS-55, I wish I got the 55 vs the 75 as well. It was the first tool I bought so I got the bigger one thinking "I don't know what I'm going to be doing with this so I don't know if the 55's capacity is too little".
I don't mind the weight, but what bugs me is the little green chipout/splinter guard on the side. You need a plunge depth of I think 33mm to engage it. So when cutting 18mm ply or even 25mm hardwood on the MFT, I'd have to cut the front profile (MFT 1080) for the 25mm piece to engage the chipout/splinter guard. I searched once for a solution posted here, but found nothing (admittedly it was hasty). I'm in the process of experimenting with extending the splinter guard in a way to have it engage on shallower cuts. More to follow once it's successful.
