Best router bit for trimming linoleum
Josh2
what is the best router bit to flush trim linoleum? My standard flush trim bit presses the black backer into the edge (just MDF in this test run), which is really hard to clean up. I also tried a bit with flush trim bit for MDF and laminates with a slight angle. Works much better but I don't like the angle and it's a pain to set up to get consistent results.
Any ideas? Would a spiral flush trim bit help because it pushes up and not sideways? Any recommendations for 1/4'' shaft?
Thanks!
Thanks! I ordered a Whiteside Spiral Flush Trim Bit with Down Cut (1/4) and will report back.
My dad didn’t have a router, back in the day. He used a carpet type knife in a Stanley and a ruler to trim lino (the hooky one). The trick is to do it with a slight angle (a few degrees) and with confidence. Short pulls show!
