tjbnwi
- May 12, 2008
Svar said:Nobody is saying its impossible. Its simply less efficient.tjbnwi said:Not being able to make narrow rips with the TS 55 is a fallacy.
Not at all. Far more efficient at times.
tjbnwi said:Svar said:Nobody is saying its impossible. Its simply less efficient.tjbnwi said:Not being able to make narrow rips with the TS 55 is a fallacy.
Not quite. You can use feather board. When the stock you are cutting from is narrow it starts to bow with every strip you cut while reliving stress. On a table saw you will produce uniform thickness regardless of bow, especially if your fence is set up the European way (ends at the blade). With track saw there is nothing you can do (your track is straight), except attach your narrow stock to another wider piece to straighten it. In addition, on a table saw you can slice your stock all the way down to the last 1/16”, not that easily done with the track.Michael Kellough said:Another point is that when cutting natural wood into narrow strips you're more likely to encounter stressed sections that warp and press against the blade. I think this is less of a problem with the track saw.
RussellS said:tjbnwi said:Svar said:Nobody is saying its impossible. Its simply less efficient.tjbnwi said:Not being able to make narrow rips with the TS 55 is a fallacy.
How can it be more efficient? With a table saw you set the fence at 1 inch for example. Then you slide the wood against the fence and rip. And repeat all day long. With the track saw you measure the 1 inch. Then align the rail on both ends of the board. And clamp it in place. Then run the saw along the wood. Then REPEAT all of this again to cut another 1 inch strip. How do you define efficient?
JimD said:Tom,
I'm interested in how you make the track static. It seems you would have to either not clamp it and lift slightly to put the new piece under it or loosen the clamp if you are clamping to move the new piece under the track.
I have found a learning curve for my track saw not really different from that with other tools except perhaps a bit larger because of the versatility of the saw. I'm sure I have more to learn.
Jim
