Bugsysiegals
- Mar 19, 2016
I’m working on some shop cabinets and accidental plunged all the way through the sides of the cabinets with the Domino. I don’t intend to hide the mistakes but before I can finish the cabinet I’d like to fill these holes and am wondering the best method/product(s)?
Some holes are in the Maple plywood and others are in the Walnut edge banding. Is there a wood filler which would match somewhat close to these colors? If not, would it make sense to fill with a wood filler of some sort near the surface and then mix wood glue and dust from the CT36 as a top coat to try and match more closely? Any other thoughts?
Using the OF1100 to flush trim the edge banding, kids started running upstairs, distracted me, I let the router dip down, and gouged the to deep ... SMH.
Using 40mm Domino's and messed up the split of 25 for plywood side and 15mm for edge banding side. Future Domino's will be 30mm to avoid this mistake.
