tjbnwi
- May 12, 2008
Cheese said:tjbnwi said:I make a lot of doors.
The link is mahogany, the photo is QSWO.
https://picasaweb.google.com/tbadernwi/CSAP?noredirect=1
The mahogany door is stunning.
Is there a reason you miterd the rail & stile rather than straight cut them? I assume it's to pick up the angles of the floating panel.
Did you do anything additional to prevent the mitres from opening?
Here is a link to the entire build and install. The first frame is the drawing I received, the architect drew it with mitered corners. That was not the biggest issue, it was labeled as 26" instead of 2/6-------oooooopppppppppsssssssssssss.
There is a picture of the 10x50 Dominos that were used in the corners to keep them joined. If the job would have moved forward with the original design the mitered corners added $17.14 to the cost of each panel.
I did not find out about the dimension error until the evening before I was to install the prototypes----in Cleveland. There are pics of how I solved the problem.
Due to budget, we did the job using flush off the shelf luan doors. Brought the job down from 500K to 150K.
https://picasaweb.google.com/tbadernwi/ClevelandRocks
