blast gate for y piece for festool extractors?
  • Thread starter Thread starter L.Alexander
  • Start date Start date
L
L.Alexander
Guest
Hi all,
I'm working on an extraction spec where I want to run 2 hoses from my CT48 but so I can keep a suitable flow through, I want to fit blast gates. Now, I can't seem to find anything in the festool manuals yet lol. Do festool make blast gates for tye Y Piece (Y-piece, antistatic D 50 SV-AS/D 50 V. P/N: 452898)?
main plan is to use 2 x 36mm hoses with cables running from two sockets on the CT48 (yes, you can add an additional 240v socket) and then as 1 goes to bench, the other goes to CMS / CS rigs, etc. asit would be easier than trailing hoses everywhere.
any advice greatly appreciated.
lew
OOPS. still trying to get used to this forum. just resolved this problem thanks to a previous thread on this. it turns out I need a pair of 497926 gates, the y piece, hoses, etc. this is going to b pricy.
lew
lew
Can't you get splitters on your side of the pond?  I'm sure that would be far more cost effective than a second outlet.  And, is that second outlet also tool activated?
lew
Yes, we have splitters, but we also get additional sockets (which looks a lot more professional). You can buy 2 different additional outlets - switching or non-switching.
I have sort of the same question on the blast gates / Y adapter. I have a 36mm and a 27mm hose running up my boom arm. Can I add a Y adapter and 2 blast gates (see picture) instead of having to switch out the hose ends depending on which hose I want to use?
[attachimg=#]
The blast gates that Festool do for the CT26 AC are quite big & numb, as well as being very pricey. You might be best finding some generic 2 1/2" gates and adapting them to suit.
Edit: here are a couple - If you're in the UK or In North America.
Remember to run a piece of wire across them to provide a static path.
Personally, I'd like to see a Y piece with a switch built in, so you didn't need separate gates...
I previously had Axminster confirm that those gates aren't anti-static, and so your comment regarding running wire is pertinent. However, I also found a UK supplier of 2.5" Blast Gates that use anti-static plastic (confirmed by Natalie Harvey at Camvac Technical Support).
See http://www.yandles.co.uk/product.php/sn/CAMCVA250-50-102
If someone is going that route and is concerned about antistatic path why not simply use a metal blast gate?
Cheers,
