Blum makes something like this aswell.
I have the Hettich setup, the whole set, and partly regret not buying the Blum set. It's more versatile and cheaper. For instance when your building shallow cabinets you can adjust the dept with the Blum unit something you cannot with the Hettich version. On the other hand, with Blum you don't have the handle jig. At the firm where I used to work, I decided to get the Blum version, worked great. Changed work and needed a set of my own, decided on Hettich because there hardware is more readably available to a home-worker. In Belgium Blum delivers straight to firms, they don't have a large dealer network. Have regretted that decision often, the Hettich harware is not up to the standards of Blum, not nearly. There jigs are nice and are usable for the Blum hardware. At my current job i decided again to go for Blum.
I also bought their planning software, Dynaplan, it's a dream to work with. It's cheaper, €100, than Hettich's, €250, it has fewer possibilities, but works much faster for custom cabinet making. The Hettich version uses Autocad to draw your cabinets in 3D so you can present for instance a whole kitchen with light and shadows in 3D, but its much more time consuming if you just need the dimensions for your jigs. On that note, if you invest in the jigs, the software is the icing on the cake. If you use it this really speeds up your whole cabinet preparation process, from cutting dimensions to adjusting the position of drawers, shelfs and hinges. Those €100 you invest are payed back at you first kitchen, at least twice in time.
If anyone is interested then I'll post a printout from the Dynaplan.
Conclusion: the hettich jigs are nice, but if you use there software and cabinet hardware then I would go for Blum.
Blum assembly devices brochure
I know all this may sound confusing, Blum vs Hettich. But the fact is that I much more like the Blum harware (and software) and that if you use these your better of with the Blum jigs.
Hettich has some nice features not available from Blum:
- handle jig
- longer rails 2000mm also have mm/inch marking
- you can make you own rails from clothing hangers bar, had to have a really short one, no need to cut your expensive "official" rail
- jigs for drilling 32mm connection hardware
- drills with adjustable spring collars are nice, but expensive
- jig for drilling hinges can be adjusted to different makes of hinges, Blum is fixed
