leakyroof
- Mar 23, 2011
Ron, the DTS paper is unique in size- The Delta pad of the RO90 and the DX93 share the same delta pad-The DTS400 is larger and not an equal triangle in shape-RonWen said:Scott B. said:tedzap said:Good advice all.
Scott, is the DTS400 better at extraction than the 90 and 93? That is one of my primary issues. I am not currently sensitized to the epoxy dust, and would rather stay that way.
I think that many of you folks strive for a finish that is above and beyond what I looking for, as my final finish will be covered with a high build primer followed by paint.
The RO150 sounds like the basic starting place.
Yes, the DTS400 is off the charts better than the 90 and 93 in extraction. However, it is not as aggressive, so the work will be slower. It is also larger.
I may add the DTS400 to my tools simply because of it's size and it uses the same abrasives as the RO90 delta pads. It is typical to invest greater than the price of the sander in the abrasives for it, sharing abrasives between machines eases that pain a bit.
The other plus for the DTS400 is it's short 2mm orbital stroke for very fine finishing.
