ApgarConstruction
- Apr 23, 2010
Hi guys
I love my new Rotex RO125 sander. I had to sand down some large 3x12 stair treads for exterior steps on a log cabin. I installed them a week or so ago but the customer told me they had a thin spot of water directly in the middle, not a lot but just enough to notice. I knew some had cupped a very slight bit but thought the pitch of my new stringers would make up for that. I had to cut through two layers of oil primer and then take off about 1/16th of an inch of wood on the front half of 4 of the 6 stringers.
(two sets of setps, three treads per set).
The rotex was hooked up to my rigid 4 gallon smaller shopvac because I was outside and the anti static hose works with it. I barely went through two pieces of rubin 50 grit and only used 1/ 100 grit rubin which is still in great shape. I completed the job and re-primed the treads I had to sand. I knew my older PC 333 wasn't going to cut this job. I did have to use my power planer on a few just to save myself some time, but the Rotex really did a great job. I was on the fence about buying this, and had planed on just buying the ETS 125, which I may do anyways in the fall.
I have one question /comment about it. I used aggressive mode for the big hogging, but the finished them off with 100 on fine mode. I noticed that once and a while this thing wanted to skate around or hop a little bit making it harder to hold onto and control.
Can anyone offer me some tips on what might be causing this. I love the barrel grip and wasn't sure I would but I do. I have large hands, so it worked great. I am not sure how anyone with small hands can grip this thing and have a good control on it.
The paper stayed so clean even when cutting through the primer/stain that was on there. I would have gone through a dozen PC discs trying to do it with a normal sander and the planer.
Any planer marks quickly disappeared with the rotex.
two thumbs up for this great tool! another systainer added to the truck/trailer!
-Dan
;D ;D
-Dan
;D ;D
