bobmeister said:
			Tim,
Just thought I'd mention one aspect that stood out to me - in my humble opinion, the top of the cabs don't quite match the bottom.  What I mean is, since the top of your cabs are wrapped in the ceiling crown, they look like architectural built ins.  But then at the bottom of the cabs you have the legs which look like furniture.
I'd suggest to either change the base of the unit and run the room's baseboard around it just as you did with the crown, or leave the legs as is but then alter the top to not wrap it in crown either.
Just my amateur opinion...
Bob
Hey Bob:
Thanks for the comments. I did consider those issues when I was first designing this but decided against it for a couple reasons:
I really liked the fireplace surround with the craftsman look to it, which influenced my design decisions somewhat. The fireplace mantle is some weird amalgam of craftsman, colonial and with some dentil molding so that's what I have changed.
When I originally proposed these cabinets there were no doors on them and the legs added some interest to some fairly plain looking bookcases.
I also felt the feet added a bit of "lightness" to the design, there is a sliding glass door on the left hand side wall which gives the room an airy feel. I wanted to compliment this affect.
I am not crazy about the baseboard they have put in this room and if I designed the bottom of the cabinets with out feet I would have to use this molding around the bottom.
I felt that if I built cabinets that stopped lets say 2 feet below the ceiling and had some sort of crown, I would loose that space for storage, and it would add another visual element to a room that is not that big and with the addition of these cabinets is starting to get quite busy looking. The room is 8' feet tall so there is not a lot of room for a visual break between the crown and the cabinet top.
Because the Crown is fairly dominate in this room, I thought I should use it to bring the various elements together.
If they decide they want the cabinets to go right against the fireplace surround, I would most definitely not keep the feet and do as you suggest.
Hope that helps explain/rationalize my decisions.
Tim
