Michael Kellough
		[member=62623]Simon O[/member]   What is TNO site?
			Simon O said:Here you go -http://www.dustfreeworking.tno.nl/dust-extractors/dust-extractor-classification
Like many I found it difficult to find independent testing or even much in the way of reviews about dust extractors - so it was great to locate this independent Dutch research organisation, which has some clear and concise information about a field where there seems to be a fair amount of disinformation.
TinyShop said:Finally, somewhat curious that they have not yet tested an H-class (HEPA-filters-fitted) version of the i-Pulse (only L-class and M-class from the look of it). Unless I'm overlooking something, I don't see one listed.
Bert Vanderveen said:TinyShop said:Finally, somewhat curious that they have not yet tested an H-class (HEPA-filters-fitted) version of the i-Pulse (only L-class and M-class from the look of it). Unless I'm overlooking something, I don't see one listed.
HEPA is not a European thing, afaik. Hence no mention.
You have to interprete the numbers in the context of the work being done for the individual test: the ratings for the Festools are when being used to extract an angle grinder cutting bricks - while others rating (resulting in higher hours per day) stem from extracting a completely encapsulated tool (which is way easier, compared to a half-open one) working on materials that don't clog bags as badly.TinyShop said:Ouch - the dust extractor rankings on this page:
http://www.dustfreeworking.tno.nl/dust-extractors?tested=100345,100344
...(which, among those machines tested, rank Starmix among the best and Festool among the worst in terms of health and safety) are sure to touch off a storm of commentary. Also of interest, is the fact that there are some surprising leading contenders like Makita for instance.
Gregor said:You have to interprete the numbers in the context of the work being done for the individual test: the ratings for the Festools are when being used to extract an angle grinder cutting bricks - while others rating (resulting in higher hours per day) stem from extracting a completely encapsulated tool (which is way easier, compared to a half-open one) working on materials that don't clog bags as badly.TinyShop said:Ouch - the dust extractor rankings on this page:
TinyShop said:Simon O said:Here you go -http://www.dustfreeworking.tno.nl/dust-extractors/dust-extractor-classification
...(which, among those machines tested, rank Starmix among the best and Festool among the worst in terms of health and safety)....
and the apogee of the commentary has been Gregor's grudging -
"Seems not....."
But if your main concerns are new hoses and hose garages and bluetooth technology, then all the above are immaterial concerns.
As I wrote: I am interested in the technical reasons for why the festool performed worse than other vacs on that task, sadly nothing in that regard can be found on that site.Simon O said:[member=53905]Gregor[/member] the TNO site makes it very clear what it's testing regime was for the various extractors read - Dust Extractor Classification, here -http://www.dustfreeworking.tno.nl/dust-extractors/dust-extractor-classification
it would be a waste of time if there wasn't a standardised test - seems so, no? The details for the test are clearly stated.
To compare the performance of different vacuum extractors, TNO has developed a standard test. This is carried out using an industrial vacuum extractor in combination with a 125 mm Metabo angle grinder, model WE 9-125 Quick (900 W), fitted with a TNO dust shroud. The tool is operated continuously for 60 minutes, grinding sand-lime brick. During this time a groove 60 metres in length is produced. Approximately 7.0 kg of crystalline silica dust is collected in the extractor. Source:http://www.dustfreeworking.tno.nl/dust-extractors/dust-extractor-classification
As well as innovating itself, TNO builds bridges to tool manufacturers. Once they have implemented dust-free tools and systems successfully, participating companies receive the TNO-Inspectorate SZW Dust-Free Contractor Award. The total cost for participants is €2000 over a two-year period. If you are interested in joining, complete and submit the contact form or call XXXX on +31 XXXXX Source:http://www.dustfreeworking.tno.nl/ministry-sae/letter-of-intent
TNO heeft tientallen prototypen voor stofafzuiging op gereedschappen ontwikkeld. In samenwerking met vele marktpartijen (Hilti, Makita, Bosch, DeWalt, Festool e.a.) zijn innovatieve stofvrije gereedschappen op de markt gebracht. Source:http://www.dustfreeworking.tno.nl/i...ations/stofafzuiging-op-handgereedschappen-en
six-point socket II said:And they are certainly not even close to be any kind of authority.
six-point socket II said:I've spent quite some time on the TNO site and it leaves me with more questions than answers and I will go as far as questioning some of the presented results/"classifications".
six-point socket II said:And then speaking of questionable:
Taking a cordless L-Class dust extractor (which is not permitted for silica dust when used commercially) and claiming it is totally OK to use this day in day out. Test claims 2000 holes/day. ->http://www.dustfreeworking.tno.nl/tools/bosch-vacuum-cleaner-gas-18v-10-and-drills
Alex said:six-point socket II said:And then speaking of questionable:
They do not talk about European regulations for the trades. The Dutch government (in conjunction with the EU) sets an amount of dust you can inhale on a day while working, which is regarded safe. If you stay under the limit you're safe, if you inhale more your health is in danger on the short or long run.
While the EU made M-class vacs mandatory for professionals, that doesn't mean an L-class vac can work so good you would still stay under the safety limit working with it all day. And that is all what they tested. The amount of dust you're exposed to as a user.
And it is not that difficult to see in this particular test combination of vac and drill. Putting an angle grinder on stone generates quite a bit more airborn dust than simply drilling a hole with a dust shroud.
