Oso Rojo
- Feb 27, 2014
Using traditional methods to make a euro style base cabinet, a rabbit is cut in all the sides so they sit partially on the bottom. This is done to transfer the load from the joint to the base.
Using the Domino and pocket screws, do you still need to make this weight transfer with the rabbit or can you hang the weight on the dominoes and screws?
