Guidance is needed regarding laying out base and upper cabinets when there are 2 or 3 banks of drawers or shelves in a single cabinet assembly. The issue is how to handle the mid-panels. I plan to use dominos for the joints and the LR32 for shelves, drawers and hinges. I don't plan to use face frames. So my design question involves how-best to plan the joinery for connecting sides and mid-panels to the bottom.
At issue is whether it makes sense to cut mid-panel(s) the same height as the L&R sides. I plan to have the L&R sides cover the bottom panel so it doesn't show from the sides. If the mid-panels are the same height as the sides, then it means the bottom becomes 2 or 3 pieces vs. a single panel. This wouldn't be noticeable on the base cabinet but it would be on the uppers (especially for short people).
Keeping the mid-panel and side panel heights the same has an advantage when using the LR32 of being able to reference off of both ends of the panel the way the LR32 is designed to be used. If the mid-panels are cut 3/4" shorter (taking into account the thickness of the bottom panel) then there is only one reference edge for the LR32, that being the top.
I hope this description makes sense. I've looked but haven't found a good reference source, YouTube video or thread covering this question and I'd like to proceed using good technique. Suggestions or links to information on the subject will be great.
As a separate question re: the sizing of dominos for 3/4" sheet goods, I'm wondering if I should use 8x40 dominos (which I have a ton of on-hand) or whether I should buck-up and buy some 6x40's or possibly 5x30's. I believe 6x40's are the "correct" size because 6mm is roughly 1/3 of 3/4" sheet goods. 5x30's are tempting because they don't require changing the depth setting back and forth but they seem awfully small...
Thanks, Rich
Thanks, Rich
