I am fairly new to wood working. I had started out with Ryobi and started to upgrade to other brands. I recently bought a TS75 and tried to square the track with a square and it worked pretty well. I figured it would be nicer to have the track square so I went and bought that.
My cuts are less accurate than before. I did a 5 cut test and over 23.75" I was off by 3mm. As I was putting the track on top for the last cut I could see a huge difference and I cannot figure out why. I tried to clamp the track on each cut and did it a second time without clamping. Results were better without but not by much.
I did use multiple squares that are all square and put them up to the TSO guide and rail and it is sitting square. I also made sure to lift the track before putting saw down in case the non skid was preventing the track from sitting correctly.
What else can I check? Thank you
