jmbfestool
ummmmm..................
ill make a video the way I make circles on site quickly. I have some plywood only so I know if your using solid wood you do have grain to contend with but you just go slower and make sure you have a sharp cutter.
Thing is I am making a circle out of ply wood you can use the circle plywood as a template as another method to cut your circle out your main piece if you wanted to instead by just simply clamping or screwing the ply piece on your work piece and then using a coping cutter to trim your piece down you first simply place your circle template on top then mark round with your pencil then free hand with your jigsaw cut 5-10 mm away from you line or as close as you dare to go make sure no wondering blade goes further past and then place your ply template back on and using your router trim back.
Any way ill post a video in a 10 mins wont take me long to make a circle.
JMB
JMB
