mino
- May 5, 2016
And the Carvex ...Michael Kellough said:Correction, my Metabo 140 base is fine. I thought it was off at 90 degrees due to the blade having a bend. The Festool blade looked brand new so I did not check it closely.
Also, like the Maffell the Metabo is set to get as close to a wall as the reciprocal housing allows without the need of base mods.
I believe the point was the Maffel base sliding back allows to cut all the way to a low vertical "step" where the step is low-enough to fit under the upper body of the saw.
Normally that is not possible as the saw bases are aligned not to the "cut start" line but to the top of the saw overhang plane. With a sliding base or with a grinded/modified base in case of the Carvex such cuts become possible.
