Tim Brennan
- Jul 28, 2013
I have wanted to buy a Domino 700 XL for a long time. The 700 has the advantage over the 500 of doing more using the seneca adaptors and the sort of work I want to do with it encompasses external doors, garden furniture, as well as drawers for indoor use. Although the first 2 projects I have lined up are really smaller scale work better suited to the 500, I can't justify buying both machines so the 700 with adapter seems the best option.
Project 1 - Repairing Dining Chairs
As you can see in the photos, the side seat rails have come away from the stile. I previously replaces the dowels with some Unibond but now they have failed (the dowels might have been pine or something not up to the task).
Some questions...
1. As shown in the photo, the rail and stile aren't perfectly flush. there is a step of about 2-3mm. Is this going to make lining up the domino slots problematic? How is it best to tackle this?
2. The rail is 27mm wide so I am assuming that 8mm dominos are the best size to get. I see that 8mm dominos are sold as 50mm long or as 750mm long rods. The stile being 32mm wide could perhaps take a 30mm deep slot. Would a 50mm long domino be strong enough? Is one large domino better than two or more smaller ones? What is the strongest configuration?
3. Which is the best glue to use?
Project 2 - Plywood Drawers for under stairs
I am going to make some cabinets with drawers on ball bearing runners and made from 18mm plywood. I have done this previously and found it pretty time consuming to fill in all the cavities between the layers prior to painting. Would mdf be better choice?
I am looking to also buy a MFT/3 for this task (I already have a TS 55).
There are many ways to buy dominos. I am thinking of buying an assortment in Systainer (Festool 498899 1060 Piece DOMINO Beechwood Assortment) that comes with a selection of smaller cutters. It seems most economical in the long run that way, right?
Here is my shopping list so far - have I missed anything useful?
Festool DF700 EQ-Plus 240v Domino XL
Festool 493487 Trim stop
Festool MFT/3
MFT FX set
Seneca Adapter
Bessey BAN700 Band Clamp
Some questions...
Festool MFT/3
MFT FX set
Seneca Adapter
