tiralie
- Jan 26, 2010
Festoller said:Any idea how to improve the drilling process
I think Guido's methodology is the best hands down. You get the right depth, the holes are perfectly centered and the proper depth and if you are using Festool routers, perfectly clean.
I use these fasteners (with a Hafele jig and drill) and they can be finicky.
The 10mm hole must be drilled precisely (vertically and horizontally) or when you install the connector it will pull the 20mm section of the connector forward which results in the connector not sitting flush with the surface of the substrate weakening the joint.
It is easier and faster to use a rafix-SE (or similar Hettich or Blum) type fitting. It's only one 20mm hole, it holds as well and I think the only risk is in the Rafix fitting turning in the 20mm hole (if bored too wide) during installation, which would make it difficult to line up the pin.
Hope this helps.
Tim
