Cleaning Set "Trick"???
ADKMedic
Happy New Year everyone!  (almost!)
I received a Tradesman/Installer Cleaning Set to go with my new CT36 and I have a question...
Is there a "trick" to getting the 36mm hose back into the systainer???
Talk about not being able to get something back into its original packaging!!!  LOL    ;D
Thanks!
Andy
I'm waiting to pick up mine from my dealer.  I think you have to heat up the systainer and freeze the hose, then quickly shove it in.
There is a trick, once figured out, it is simple.
I am able to fit quite a few other things in there as well.
Chris, that was too easy so it doesn't count.  Sorry.
Darcy had the best answer and Brice gets points for his artistic abilities with Sketchup, although I believe there's a post of him towing that thing behind his truck.
The prize committee has approved these limited edition gifts delivered in an exquisite corrugated presentation case.  Congratulations to all and enjoy!
First laugh of the new year goes to Ken well done... [big grin] [big grin] [big grin]
I thought it would be Jmb [big grin]
Wrap a towel around your head, sit cross-legged on the floor, then start playing a section of the hard pipe like a flute.  The hose will coil itself back into the Systainer pretty quickly.
Chris Rosenberger said:
Get a Systainer 5.
Did you forget the Festool Motto?
Faster, Easier, Smarter    [big grin] [big grin]
Ken Nagrod said:
...Darcy had the best answer and Brice gets points for his artistic abilities with Sketchup, although I believe there's a post of him towing that thing behind his truck.
Yes, I've towed that thing before, but you've got to be very careful when starting and stopping..... [blink]
Get a Systainer 5.
I stand corrected!  Chris will be receiving a limited edition (1) autographed picture of Shane.
Thank you Chris and congratulations as well.
I too bought the tradesman/cleaning set. I found if you coil half the hose in and then put in the beater bar in and then finish coiling the hose in. Kinda weird. Not too well thought out, but either is the splinter guards that fall off the tracks when you are not using them.
I hang the hose over my scroll saw. Tried once to get that puppy back in the box and once was enough!
