Hi.
I work with parquet, laminate floor ...
Is there much difference between these two vacuum cleaners? Is it worth buying the CTM?
I understand that the two are practically the same ...
Do the two models aspire equally well?
I do not know if it is worth spending more on the CTM if it aspires just like the CTL.
I will connect it to the Kapex 120 machine, to cut DM skirting boards.
I will also connect it to the TS55 machine, to cut the doors of the houses, but that is not much work.
In principle I will use it with the aspiration bag and maybe with time I will buy the cyclone from Festool.
I do not worry about the dust bag, I empty it and I clean it almost always.
To me the air outlet is good for me, since after cleaning and vacuuming the Kapex machine, there is always some dust left and in this way I throw a little air and that makes the machine much cleaner
I also thought about buying the CTL 26, but I suppose it has the same suction force and it does not have air outlet either ...
Thanks and regards.
Thanks and regards.
