RobWoodCutter
- May 16, 2010
Two things:
I would like to see the CMS power switch moved to the front. I already made an angle bracket and shifted mine to the front (sits horizontally) but it is in the way of the legs when folded up. I have no need of folding the legs at this point so it is not a big deal. I may try working on a more complex mounting bracket in the New Year to push the switch up and back so it would clear the legs when folded up. This allows better access to the switch and allows you to mount an in-feed support table as well.
The second is a Domino "dowel" center similar to a normal dowel center but elongated to match the outline of the end of the domino with maybe some cross hairs. This would allow for free form Domino'ing on a contured surface. They would have raised markings that could be punched into the second surface. With a normal dowel center you just need a center point to know where to drill. But a domino needs a cross hairs to you can see the centered location and the alignment angle. A nice kit of Domino Centers to include all of the Domino sizes.
Rob
Rob
