CMS TS75 switch clip issue
Status
Not open for further replies.
Does any one have any tips for a fix for the TS75 switch clip. It gets so hot here that the plastic gets so soft it just turns of from bending. I was gonna cable tie it but didn't know if any of you guys had this issue and knew of a fix.
This is an interesting post to have on the forum.  If I understand the question correctly, an owner here in the US has a a TS75 mounted in a CMS module.  That combination is not offered here and thus not supported,
The poster has asked a question about a Festool part that locks the TS-75 trigger into the on position but it doesn't operate as designed and supported in other countries.  The poster has asked if others have an issue and if there is a work around.
A work around the Festool system would be something that would not be permitted to post here for obvious reasons.
This thread is being locked.  If any members want to share thoughts with the OP in private that is beyond the public side of the forum.
Peter HAlle - moderator
Status
