I'm new to Festool but have been woodworking for a long while. I got the TS 55 saw and rails and have been using the MFT/3 for some projects. Yesterday I had a full sheet of plywood to break down so I took the rail I got with the saw and the extra 55" rail along with the two connectors as was recommended by the sales guy. Put it together and thought I was happy.
I attached the two tracks and did an alignment to get them straight, everything looked fine and I did my first cut, a 2" wide full 8' long. Then started the series of 3" strips. I checked to make sure they were the correct dimension and repeated the cuts. When I finished there was a small strip of scrap. Looking at it I could see it was wider in the middle then at the ends.
My first and correct assumption was that track(s) were no longer straight. I wasn't sure if I had some how not had it straight to start but when I stated checking I found that about 3 cuts in the rails had gone out of alignment and the cut was no longer straight but a long curve from that point on. Checking the tracks verified the arc.
The good news is that this is just a test shelf unit for the garage and can adjust the design to live with the parts as is. But I have other more critical projects coming up and need to figure out what I'm doing wrong before I waste expensive wood.
It was a simple cut and index operation and the track was not subjected to being carried about or moved about any more then was necessary. I checked and the screws were all tight. I did leave the space between tracks per the instructions. I still have 5 more upright pieces to cut after I route some dado's in them but I really need those to be right.
Thoughts about what I did wrong and how to fix it? (Rather not have to buy the longer track section for this.) Up to know I've been loving the system!
Ed
Ed
