nowandthen
- Jul 20, 2012
I am planning on building a 4' x 8' "MFT". I've seen various ways to attempt to get the holes exactly on grid so one can take advantage of the holes for squaring etc. I'm contemplating purchasing the LR 32 to layout the 20mm holes. Seems to be the most idiot proof. Not sure I can justify the cost but I'd like to ask a few questions "just in case".
Rails:
Q1. Is is possible (and accurate) to use one 55" guide rail to lay out the holes? Not sure how I would register the guide to the first set of holes when laying out the 8' long rows.
Q2. If answer to Q1 is no, or "tricky" etc, can I connect two LR 32 55" rails end to end such that the hole pattern is continuous without error? Reason I ask is two 55" rails and connectors are less expensive than the LR 32 95" rail. I already have a 32", 55" and 106" rail so I don't really need another long rail.
LR 32:
I'm thinking the LR 32 Drilling Set in Systainer (584100) is more than I need or want to pay. I don't need the 32mm boring bit, I do need to buy the 20mm boring bit.
The LR 32 Drilling Set (583290) is more reasonable, price wise. I don't get a shelf pin bit but I can buy that extra and still be ahead.
I also see there is the LR 32 Guide Plate (494340). It does not include the edge stops.
Q3. How much value is there in the edge stops (485758)? Perhaps I need them in order to get by with only one 55" rail? The Guide plate is the most cost effective solution. I do own the Festool Parallel Guide and Extension Set (P00108). Could those work instead of the edge stops? I know they have no pins but keeping the row in line with the first is what I'm thinking. Then use 5mm(?) pins to register the holes to the first set of holes?
I think I may need the 5mm bit in order to set a row of indexing holes along each long edge, from which the guide rail will index off of. I hope this makes sense.
Thanks.
Rails:
LR 32:
Thanks.
