Connecting top and bottom of a Hutch
ear3
New York, NY
I'm designing a hutch style piece of furniture, with file drawers on the bottom and a bookcase on the top.  Generally hutches have separate construction for the top and bottom, which are then fitted together.  I'm just curious about what hardware or fittings are usually employed to connect the two pieces.  Is it just dowels (which presumably could be replaced by dominoes)?  Are the pieces sometimes secured together by hidden screws for additional security?  Here's a picture of a basic hutch design to illustrate
Mostly gravity with a little bit of registration.
I’d put shortened dominos in the base so they only project 1/4” or less. Maybe half that. Chamfer the projecting ends and chamfer the mortise.
Reason for putting the studs in the base is so the upper can be slid into final position without scratching the base.
I'd use dominoes, too, just because I have a DF500 ( [tongue]). But screws will work as well -- securing the bottom rail to the hutch top (lower case).
I'd also use some very short Dominos for registration of the 2 pieces. I like the simple peg in a hole idea versus a threaded fastener.
The hutches I've moved for people have never had any attachments what-so-ever, just 2 flat surfaces.
I had one a while ago inherited from my parents. That particular was American made.
It was just flat surfaces, as Cheese said. Never experienced other than a short flat bar screwed between top lower section and lower top section at the rear. This would prevent tipping of the top section once in situ. It depends on the height and base depth of the top section, whether it should receive some aids to prevent tipping or centering.
