thats the kind of thing im thinking of, i think the cms fence attaches into holes in the table rather than a t track. that why i was thinking of using the v groove on the side.Don T said:Wouldn't something like this Kreg Micro Adjusterwork for the micro adjustAlan m said:maybe someone (ron maybe) could make a fine adjust for it. have it clamp (mechanism like the ug wings or crown stops) into the v groove and have a threaded rod pughing the fence. just loosen the fence and turn the screw ,then push the fence up against it and tighten.
Rocky said:What is the amp rating of the router table switch?
Eco-Options said:What are the chances of Festool selling just the table? Anytime soon?
Shane Holland said:Eco-Options said:What are the chances of Festool selling just the table? Anytime soon?
Without the router module - nil. No plans and I don't see it happening unless other modules pass UL at some point in the future. What good would a table be with a big hole in it?
evanism said:Interesting that the date on this tread is recent.
I'm in Australia. I've had my VL and router base for about 3 years. It is OK, but there are a few things that have irritated the socks off me:
- the lack of ability to simply use a standard mitre gauge rather than the big slide doohickey from Festool
- the lack of rail guides in the table top
- the fence setup is impossible to set exactly. This is no Incra LS type fence (in fact you can't fit one without making a component to hang onto the extruded rail....
- The fence is wound on with two long screws and offers no adjustment other than with a hammer of fist. Line of sight stuff. Very un-festool. It seems odd the way its mounted. Its not stiff, accurate, repeatable or offers wide adjustment. This one stuck me in the first second of opening the box. I use a long bit of timber from the dogs mounted in the MFT to get it parallel and centred on the bit (my trusty Bit Of Wood Measurer)
There is one redeeming feature, in that the fence can be used as a jointer for small work due to the winding offset for the right.
If Festool were to just add some rail guides it would be perfect.
Tom Bellemare said:did I read somewhere (in this thread?) that the CMS router hole is much smaller?
It's slightly bigger.
Tom Bellemare said:Slightly bigger than 3-3/4".
Tom Bellemare said:The 1400 & 1010 are right at 2-3/4".
