A
Administrator_JSVN
Guest
Jack, since you specifically addressed me, I'd like to post an answer. Unfortunately, that answer is that I don't know for sure. The CMS is designed for Festool routers. But that doesn't mean that other routers may work. It would need to be a plunge router, have three points on the base where the hold downs could attach the router to the router module, it would need a power button lock to keep it in the "on" position, and there would need to be a flat where the lift could make contact. Then, you'd need to ensure that the router is centered using a mandrel. The OF 1010 and 1400 have a small metal "key" for lack of a better word that engages with the base and assists in centering and placement.
Edited - Using a router other than the Festool OF 1010 or OF 1400 is prohibited per the manual and would void the warranty. My apologies for not stating this before.
Shane
Shane
