Contemplating Planex purchase??
BJM9818
Hi everybody.  I am on the fence on purchasing a Planex.  Currently I build 2+ spec homes a year and pick up 1-2 full rehabs I keep for rentals.  I sub out all my drywall work but that doesn't eliminate sheetrock repairs for missing wires/plumbing and the usual BS that goes along with construction.
I have an upcoming remodel project- 4000ft2 home that needs updating- 2 full 1- 1/2 baths/add a bath/Kitchen and everything else. Some ceiling work.  My guys normally use the Festool hand sand vacuum attached rs2 and ls130 paper size sanders.  I have 2 midi's and a 36 but I will most likely pick up the 36AC regardless of the planex purchase because drywall does kill my Midi's/36 useful bag life with the hand sanders.
I can understand where it would save time doing an entire house but not sure if the dust collection and time saved would be worth the probably $1400 investment after factoring in accessories and paper. We are talking about a lot of little areas.  Budget for the job is generous but already picking up a 36AC/ Duo syslite and possibly the HKC.
You seem to be the perfect candidate for trying it out under the 30 day trial period.  The worst off that will happen is that you won't find it working in your own situation.  Of course you will have a learning curve to toss into that equation, but if it meets you needs with the learning curve then it should surpass them later.
There are many accessories for the Planex and as such they are not included in the trial period, so be aware.  Also, if you buy from an online dealer and decide to return then shipping back will be on you.
Peter I may not have been to clear in my OP. I know it will be worthwhile in this upcoming job just asking if it's worth spending that much money when going forward I will only be using it for small spots here and there.
I bought one and I only have one house and a rental.  I do almost all of my own rehab work but I hate the drywall sanding.  I had a porter cable and didn't like the dust collection.  I gave it to my son and bought the Planex.  The dust collection is much better but you still get some side spray if you tilt the sander.  I haven't used it a ton but it just makes my life easier and a job I dislike less unenjoyable.  I'm always redoing something and this helps.  Besides, my newlywed daughter bought an old house and I've been helping out occasionally with that and my wife's family cottage summons from time to time.  Anything that keeps the mess down and means I don't have to hand sand makes me happy.  Its worth it to me.
Dale
Just because it has not been mentioned, library ladders, once you get past the cost of the hardware, are easy to build and I believe add to the resale value of the home.
I did consider using rolerblade wheels (very cheap) and a shop built oak track to make one of these. But it seemed too ambitious to me (but less ambitious than the folding stowaway ladders being discussed.
A set of rollerblade wheels (not roller skate) is $40.00 for a set of 8 wheels from Walmart. They were a lot cheaper the last time I looked, but they now come in black (and other colors) and they used to be in clear only.
Im curious about the library ladder response, do you install them so you can sand with a handheld sander vs a planex? I can seem to understand how just installing a library ladder adds resale value to a home?
I really can't believe that simply adding a library ladder to a house will elevate the value of the house...if that were the case, every house in the US would have a library ladder instead of a double car garage. 🤣 Besides, a library ladder is a very kitschy thing that reduces the living space in a homestead and is generally considered an eye sore unless you're a huge fan of the Dewey Decimal System. 🤣 🤣 🤣
You can always keep an eye on Festool Recon - you may not get the newest model , but the cost savings can be significant. I picked up an LHS225 a couple of years ago for $625 for doing ceiling patches during a remodel. Worth every penny. IIRC the newest version was ~ $1200 at the time.
I used an Oneida cyclone in-between the CT Midi and sander, worked great, helped extend the bag life.
