nobdyspecial
 - Sep 11, 2020
I've almost decided to purchase the Conturo to help me complete a couple of larger projects. But before taking the plunge, I need a little advice.
I'm using a 3/4" Panolam designer laminate (particle board), and my distributor gave me 1mm 7/8" edge banding for it.
All the videos I've seen on the Conturo show edge banding that is 3-4mm wider than the edge. It appears that the Conturo applies the banding with about a 2mm overhang at the top. The size of my banding won't support that.
So my question is whether I can use the Conturo with banding that is much closer to the size of the panel?
Thanks in advance!
Jonathan
Thanks in advance!
Jonathan
