Converting HL-850 Planer to metric
dlu
Any idea how feasible it would be to convert the imperial version of the 850 back to metric?
I'm curious about what actually gets measured on a scale with this particular tool...
I have the 850 and never paid much attention to the scale. If I am looking for a certain depth of cut, I trial and error on scrap.
Not sure, but I believe the part you need to replace is 31 on the parts diagram. If I'm right, the metric version is part number 715053, and it is described as a "Cam". This is the only part in the vicinity that has a new part number, compared to the metric version.
Hopefully you can get into that area by removing the screws in part 35, but I haven't done this.
I’m with Birdhunter on this. I’ll plane stock and check it using calipers. Same for tasks like slot routing where the depth of cut is super-critical. I make test cuts and check the depth manually, and then make whatever micro-adjustments are necessary. I think it probably all stems from tools I was using 30 years ago whose gauges were little more than guesswork.
