Could the Carvex do this?
fritter63
Retailer
Central Coast, California
Spent yesterday morning making and installing the "Corbel caps" for the fence I"m building. the posts (and therefore the caps) are 6x6 doug fir (5 1/2" nominal). I had to get a new bandsaw blade to make these cuts but then it was easy.
I thought I'd saw something like a 10" carvex blade, so for those of you that have one, would you attempt to make this cut with a Carvex? (see pics)
Thanks.
[attachthumb=#]
[attachthumb=#]
The maximum cutting capacity of the Carvex is the same as the Trion jigsaws (PS/PSB 300) and that is 4-3/4". It's limited by the length of our largest blade. The blade is 5-3/4" (145mm) in length but there is 1" travel in the blade.
Someone on here used the Trion for similar cuts on a purgola a or  gate arbor,  but they must have been  less than 6"
Thanks Shane. Must been a metric conversion error... :-)
