The OP is referring to the Precisio CS50 - a Table Pull saw, kinda like the Mafell Erika saw. For crosscut, you can clamp the wood to the table/fixed miter gauge and then pull the blade into the stock. Travel is a bit over 300mm I believe.
Blades have a star cut-out, and since the locking mechanism is by hand, you really need the star pattern so it doesn't slip.
