chriscurnow
- May 14, 2017
I took my CT-Mini apart a few weeks ago because it stopped working. I'm not sure what was wrong because when I hooked everything up again (without putting back together - just hooked up all the wiring), it worked fine.
Anyway, I gave it a good clean out and put it back together. Or nearly back together. Everything is fine except for the mains terminal block - i.e. where the main power cable comes in there is a terminal block with spade terminals and screw connections for the main cable.
Problem is I can't for the life of me work out where the terminal block goes. I know there was a screw holding it in and I have that screw. But I can't see anywhere for the screw to screw into.
Can anyone help me out here? It must be really obvious but I am missing it.
