CT wheels, 22 = Midi ?, CT for use with router table
Lucky Dave
Considering mounting either CT 22 or 26 inside custom MFT cabinet. Wheels are not helpful in this configuration. Has anyone removed and placed on blocks?
Are CT 22 spcs exactly same as CT Midi?
Also starting to plan router table compatible with custom MFT cabinet (not Festool router, about 2HP). Would CT 22  or 26 be close to adequate? IF not, what might be lowest cost, smallest space alternative?
There are no vent holes or other openings on the bottom of the CT's. I see no reason why they can't be placed on a pad without the wheels. The only issue my be resonance while it is running.
26 and new Midi are the same specs, not sure about the 22.
Any of the CT's would be adequate, only question is how often you want to empty them.
Also note that a router can fill a CT very quickly.
