Cheese said:
rbrt86 said:
...but I'm your typical weekend warrior so I'll hardly use it on the road, the hose garage and systainer support are not really relevant. Actually I'm still doubting if I should use a Dust Extractor for sanding at all, as I mostly sand outside.
The dust extractor does more than just vacuum up the dust, on Festool sanders the dust extraction, through a series of holes & channels in the pad, also cools the pad and sandpaper. If a Festool sander has "Turbo dust extraction", "Multi-Jetstream", "Jetstream" or "Multi-Jetstream 2" then the pad & paper will run cooler and last longer.
The BT is very convenient when changing grits. When I change grits, I remove the hose from the sander, vacuum the wood to remove any dust, remove the sand paper and vacuum the pad, then put on a different grit paper, reattach the hose to the sander and carry on. I'd never purchase another vac without BT because of the convenience factor.
Thanks everyone, you seem to have convinced me to buy a dust extractor, I can see the advantages over not using one, even outside.
However there is one thing that keeps me doubting: For the additional
85EUR upgrade between CT15 and Mini I get:
[list type=decimal]
[*]bluetooth function
[*]hose garage
[*]AntiStatic smooth hose
[*]filter cleaner
[*]foot break
[/list]
Given the price of the AS hose alone I can live with that.
But the Midi is
40EUR more expensive compared to Mini, and the upgrade is:
[list type=decimal]
[*]a larger dust compartment
[/list]
This is why I thought the Mini sounds like a better deal?
ghhsolutions said:
If you can afford it then I would get the Midi, you won't regret it and you will never be thinking "I wish I had just paid that little bit extra to buy a Midi"
The Mini is a Midi with less dust capacity. They both use the same bag but in the Mini you can't use all the capacity of the bag so you will spend more on bags. I was about to buy a Mini until the Festool rep told me this and I bought a Midi.
Do you guys think I'd regret getting a Mini over a Midi, given that I'll mainly use it for sanding anyway? Or is this a nice way to save 40,- ?
