F Flyfisher Member Joined Jan 29, 2008 Messages 7 Feb 8, 2008 #1 Has anyone connected the CT22 to any non-Festool mitersaws? I have a Hitachi with a 50mm dust port that is too large for the Festool 27mm hose or any adapter that Festool has in their catalog. Ideas appreciated!
Brice Burrell Member Joined Mar 13, 2007 Messages 7,325 Feb 8, 2008 #2 A couple of options, get the 50 mm hose from Festool or try a non-Festool hose on the CT. I think both will work.
F Flyfisher Member Joined Jan 29, 2008 Messages 7 Feb 8, 2008 #3 Thanks Brice. BTW, I appreciate the work you have put into sharing your website projects. Very nice indeed.
semenza Festool Moderator Festool Moderator Joined Jun 24, 2007 Messages 10,286 Location Fingerlakes Region NYS Feb 8, 2008 #4 Hi, I know for sure that Shop Vac brand hoses fit the CT 22 33. If the Hitachi takes tat size too you are all set. Seth
M Mike_Chrest Member Joined Jan 26, 2007 Messages 385 Feb 10, 2008 #5 Flyfisher, I have the Hitachi-C10FSH and the Shop Vac size hose will not fit. I ended up putting a rubber plumbing fitting http://www.citysupplyhouston.com/cat/fernco/1056_22 over the dust outlet and snugging down the hose clamps. Cost about $4.00 at most hardware stores. Mike
F Flyfisher Member Joined Jan 29, 2008 Messages 7 Feb 10, 2008 #6 Thanks for the info and link Mike. I tried the shopvac route and you are correct. The rubber fitting will work fine for my needs.
M Mike_Chrest Member Joined Jan 26, 2007 Messages 385 Feb 12, 2008 #7 Your welcome. ;D You would think that with the size of the US market the tool manufactures would make dust outlets to common sizes ??? Mike
