CT26 secondary power outlet installation
ChuckS said:
Thx for the explanation. So the tap adapter may work for some but not others. I'm unfamiliar with the CT26 BT, and how or why the addition of a tool would disable its use.
There is one "upgrade" slot on the CT26/36/48 series vacs.
It can be used either for the Bluetooth and compressed air pickups, or for the additional socket modules per this thread.
I hated having to plug and unplug various tools into the CT, and really didnt like the hose with built in plug it for the same reason. I made a plywood platform with 3d printed adapters that attach to top of a systainer. On that platform I attached a simple 6 outlet plug strip so that I only plug into CT with a cord once a day, and various tools are plugged in and stay that way all day. I also routed a slot in platform so circular saw can sit there and not tip over. I have tripped the breaker on the plug strip maybe twice in 5 yrs. I really live this set up
There is one added advantage of not plugging into and unplugging from the main socket on the CT unit itself: eliminating the chance of wearing out the socket prematurely, which may require its replacement. I use a short cord and a tap adapter to provide extra power outlets and for ease of access.
Any pics? sounds Like good setup
I stopped wasting my time trying to post pics here years ago but Id be glad to text you a pic or two.
Dave 805-302-6057
Cogy Gago said:
[member=12043]Reiska[/member] do you know if a 110V version is avaiLabLe ? Can't find anything onLine..
Sorry, can't help with that as I'm in Europe and we run on 220V here.
For the CT MIDI & MINI, it's a 3-way adapter plugged into the Festool outlet...similar to what Chuck showed.
For the CT 22, it's a SYS-PowerHub plugged into the Festool outlet.
[attachimg=2]
