- Jun 24, 2007
I had finished up a job and it was time to check / change vac bags, empty the cyclone, etc. I had been using a CT48 for the first time for a couple of months. I kept checking to see how full it was expecting to change the bag each time. Nope, not yet. So I just kept filling it to see how far it would go.
This thing is packed hard. The only space left is that shallow depression under my hand. It's so tight I couldn't get enough space to pull the bag off the nozzle and shut the gate. I ended up using the 4" DC hose to suck some out to make room!
The vac container was almost spotless. I didn't clean it before this picture. No visible dust on the main filters either.
[attachimg=2]
These two are for scale. That is a Systainer five. I weighed the bag. It came in at 30 pounds. Mostly TS55 dust. Some sanding. Very little router or floor cleaning.
[attachimg=3] [attachimg=4]
The CT 48 replaced a CT33. The 33 is now powering a CT-VA-20 cyclone. Which by the way works just fine. Personally I think it is a waaaaay better form factor with no fuss hook up, and easy emptying compared to the other brands of small cyclones. Pics of the dust bin 3/4 full. Mostly router , and pocket hole dust.
[attachimg=5] [attachimg=6]
[attachimg=2]
