Birdhunter
- Jun 16, 2012
I find that most wood, as it is cut, moves as internal pressures are released. That movement can affect a cut even on a stout powerful table saw. Also, wood with a pronounced grain can deflect a saw blade. I've even seen cuts that look perfect move after a few hours as the wood "relaxes". This is usually only true with highly figured wood.
Again, if i were trying to use a track saw (or even a table saw) to make the 45 degree cut, I'd do it in two passes if the cut had to be perfect. The second cut is just a shave.
I usually make several test cuts for beveled cuts each measured with a Starrett protractor tool. I also premeasure the angle of the saw blade. I normally ignore the saw's markings if the cut is critical. This may sound tedious, but it is faster than going back to the wood store to buy replacements for badly cut wood.
