MarkoSharko
- Oct 23, 2014
I'm trying to cut a stopped groove in a piece of wood 12" long by 4.5" wide by 23/64" thick.
When using the OF 1400 with rail guide, there isn't enough wood under the rail to get a secure hold. The router causes the wood to twist out of position (which ruins the groove).
What do people do?
- I don't have other pieces the same thickness so "building up" some sort of base or using double-sided tape on the sides are not options.
- The wood is too thin to use horizontal clamps that might otherwise go under the rail or MFS.
- Using the MFS system has the same problems as above.
Any help would be great
What do people do?
